Solvent CV over water-based sealer?!?
2/1/23
Pdub Member
I just got a data sheet for Sher-wood 5421W Gen II Universal Primer. It's a waterborne acrylic primer and it says it can go underneath all the waterbornes, but then also lists all of the CV products as well. Anyone done this? Seems to go against everything I've learned over the years...
2/1/23       #2: Solvent CV over water-based sealer? ...
Pdub Member
...Looks like ML Campbell has a similar product called Aqua-Fi
2/2/23       #3: Solvent CV over water-based sealer? ...
I looked up the MLC one. It says it's compatible with ALL of their topcoats. They write ALL in caps. Not me.
People tend to make comments about flexible over brittle no brittle over flexible. The reality is the first coat(sealer/primer) is different. It's bonded to a stable hard substrate, therefore it should be stable and can be top coated with different products.
2/2/23       #4: Solvent CV over water-based sealer? ...
Mastercabman
It does state that any ML Campbell waterborne or solvent based can be used on top but wait at least 2 hours before using solvent (75°/50% humidity)
2/2/23       #5: Solvent CV over water-based sealer? ...
Leo G
Wonder if that includes their solvent base 2K Poly.
