Turino
2/2/23
Jim Kolar
We are currently spraying Turino on a project that is from the clear base dull finish. The color is SW 7045 Intellectual gray. Not a dark color but getting inconsistent dry times with pieces. We can spray 20 shelves and 1/3 of them are tacking and dry time is long, but the other pieces are drying accordingly. All the same can and properly catalyzed. Turino has been a struggle at times like SW iron ore (dark color) is something I won't shoot anymore because of the dry times. I just don't understand the differential in dry times with the shelves.
2/6/23       #2: Turino ...
Josh Koschak
Were the shelves cut out of the same sheet as well?
I am wondering if the variable is in the shelf, or on a possible previous coat on the shelf?
2/7/23       #3: Turino ...
Scott Member
Unable to tell you what your problem is, but I can tell you that I experience the same problems with clear base turino. Darker colors are worse. My supplier say's people love turino but I hate it. I would like to try dark colors in Stealth but my suppler won't do dark colors in Stealth so I have to use turino for the dark colors. I have thought about trying some kind of drying lights to help out.
2/8/23       #4: Turino ...
Mastercabman
I'm interested in this subject
I met some people that claims the same
I never had any problems with drying time when using Turino
However I never spray a dark color Turino but when I do have a dark color job I get the primer/sealer tinted to the chosen color then top coat with clear
That has never been an issue
I have used vinyl primer/sealer and then top coat with klearvar,Krystal or back in the days with Magnaklear
2/8/23       #5: Turino ...
Jim Kolar
Thanks for the replies. The shelves we cut were HDF so I don't think materials are an issue. We shot ML Campbell universal primer which has worked really well for the base coat. We are getting through this project with turino but going to give chemcraft 24 conversion a try. I just need to get one product under the roof for my conversion varnish that has consistent dry times.
6/9/23       #6: Turino ...
Cody
Your supplier should also be able to tint Krystal to dark colors. Try KwikClaw or KwikClaw 2 for your primer.
