2k satin finish
5/24/23
Greg
Sivam satin fish is dimpling. Thinned 40%
5/25/23       #3: 2k satin finish ...
What are you spraying it on?
5/25/23       #4: 2k satin finish ...
Greg
Leo,
Grain filled walnut veneer sealed with sivam lbe 192 sealer. CAT air assist
5/25/23       #5: 2k satin finish ...
I don't know anything about the Sivan system, never even heard of it until now as a matter of fact.
Walnut is pretty grainy, which is likely why you grain filled it. Are the dimples showing up at deep grain points? I deal with this when I'm doing Oak.
You either need to go much lighter on the finish or much heavier. Whenever I'm doing Oak and want a smooth surface I do three heavy coats (of Polarion) thinned at 30% and let it dry overnight and then sand it back pretty hard until it's flat with no shiny spots. Sometimes I don't have enough finish on and have to do another round of coats and repeat the sanding. Then a final coat with my preferred sheen.
Lots of extra work which I'm sure you thought the grain filler might eliminate. The hard sanding takes away most of the finish so you don't really have issues with mil thickness, or at least I haven't. But you have to be careful of it shrinking back over time and the grain pattern showing up in the clear coat. Spraying and waiting a few days before sanding is preferred so the finish shrinks completely before you sand. But then you risk the full strength of the cured finish and will likely burn through a lot of sandpaper to make it flat. Don't ask me how I know that LOL.
