Merkur es 15:1
4/5/24
Roy Cameron
I am thinking about upgrading from my 5 stage Apollo turbine to a pump. I spray waterborne Axalta coatings. Does anyone spray waterbornes with a Merkur es 15:1 pump?
What can you tell me about tips, gun setup, ect.
I know I will need the full stainless model.
Roy
4/5/24       #2: Merkur es 15:1 ...
herb johnson
roy, first off, almost any 15-1 pump can spray that, typically with a .11 or .13 tip. you might want to start off with a smaller tip to get used the speed of air assist or air mix gun. almost all the major brands now have all s.s. components including hose ends. i would get a demo from one or two industrial distributors, watch the person demo ing it......a lot can be learned if the person selling knows what to do and how to set up a pump.....also look into a binks, kremlin, or wagner unit,......good luck herb j
4/10/24       #3: Merkur es 15:1 ...
Jim Kolar
I had a Merkur es 15:1 and sprayed clear coats and pigments fine but primer solvent was a struggle. The es is an entry level pump according to my rep. I switched to a Kremlin 15:1 pump. Alot more money but really happy with results.
4/14/24       #4: Merkur es 15:1 ...
Nick Sinderson
In the past when l was using Axalta, Sherwin William's and Chemcraft (I live in a small population area and during covid many products became unavailable so l was often switching WB to what was available in my area) All of these products l found sprayed better with a pot and gun, (stainless steel Binks pot mated to a Sata 1000k 1.3 set-up or even better with a
turbine set-up [though l almost never bothered with the turbine in the booth but l did use it when l was working on-site]). These spray set-ups limited the sherring and resulting micro bubbling that was common when using thinner American made WB's. Now that l'm using a Euro 1or 2k poly (Sirca/Gemini)l've found the euro poly works great using my Binks14 to 1 AAA set-up...no micro bubbling and much faster production).
The point being sometimes in a world of evolving chemistry/products/tools there is no simple answer too getting a great finish and making money doing it.
