Forestry
question about oak trees
8/21/23
Chris
I had a 15-year-old oak that was cut down in my backyard and I want to use the wood to build some shop furniture. Do I need to dry the wood in a kiln or can I use the sun to do that? How long does it need to be dried (kiln or otherwise) before I can safely use it?
9/1/23       #2: question about oak trees ...
Dave Edgerton  Member
About 1 year per inch of thickness usually. You can build a mini solar kiln for it. Lots of ideas online.
11/22/23       #3: question about oak trees ...
Ninareyes Member
Yes, you need to dry the oak wood before using it for shop furniture. Sun drying is a viable option, but it can take several years to reach the desired moisture content of around 6-12%. Kiln drying is a faster method, typically taking a few weeks, but it requires specialized equipment. Regardless of the drying method, it's essential to monitor the moisture content regularly to ensure it reaches the appropriate level for furniture-making. Once the wood reaches the desired moisture content, you can safely use it for your shop furniture project.
    • American Vision Cabinets
    • Forestry.com
    • RT Machine Co.
    • American Fabric Filter Co.
