Furniture Making
Subject: Re: desk top veneer and nosing
3/2/15
Ed Member
I have been using two methods of applying nosings to veneered desk tops. One has the top veneer butt the nosing showing a visible separation line from above but protecting the veneer. The second method has the top veneer overlap the nosing eliminating the visible line from above but making the veneer more susceptible to damage. This second method also allows me to shape various profiles after fabrication and is also quicker for radius tops. Does anyone have any experience or opinions on these method? See attached file.
edge_4.PDF
3/2/15       #2: desk top veneer and nosing ...
I have done both many times, but confess to liking the first method first - with the veneer butting the edge, not lapping over the solid.
I think it shows a slightly higher level of craft, and is therefore desirable. The joints have to be tight and clean - especially on radius work. You can size the panel as/when you like, and then add the solid edge.
Also, if you get into something with a wide perimeter - a 3" table rim for instance - this method will be the only way to do it and look right. You can even run a little v-joint gutter between the two if you like.
3/2/15       #3: desk top veneer and nosing ...
I have never overlapped the veneer. I always break the edge, sometimes not much, but any sanding on the edge would take the veneer to a knife edge. Way too susceptible to damage.
3/7/15       #4: desk top veneer and nosing ...
John Ten Eyck Member
I think a lot depends on the style of the piece. I replaced the veneer on this dresser top, using the same approach as originally done. With some other styles, that would look completely inappropriate, For a modern style piece it wouldn't look good, IMO; that's where I'd use your method 1.
John
View larger image
3/10/15       #5: desk top veneer and nosing ...
markbattles Member
Website: http://v-dubfurniture.com
