Furniture Making
Tapping plexiglass
3/21/21
heath Member
Say you had a 1/2" thick sheet of plexiglass and needed to tap a hole that was drilled beginning on the edge and continuing in 3 in. What type of thread density would you choose, coarse or fine? The strain on the anchor will be fairly minimal.
3/21/21       #2: Tapping plexiglass ...
Jon Member
I would think coarse since it is a softer material when compared to steel. Each thread would be larger and less likely to fracture.
Think coarse vs fine thread wood screws and their prospective uses.
3/24/21       #4: Tapping plexiglass ...
Nicko Member
I made a blade cover for dust collection over my table saw blade. I made it out of 3/8 Lexan. I drilled and tapped all the holes with fine thread. It had survived for about 13 years. It probably doesn’t matter what thread you use. Plexiglass is pretty brittle. You get more threads per inch with fin thread.
Nicko
    • Anver Corporation
    • CP Adhesives
