Furniture Making
Douglas Fir Cracking
4/7/21
Kabeer  Member
Website: http://www.wifie.com
Hi,
Can anybody advise me, what could be the cracking cause in kiln dried Douglas Fir species, as it is cracking after making console and dining table tops .
Is it not good for furniture manufacturing? Please suggest any solution for that.
Thanks in advance.
4/7/21       #2: Douglas Fir Cracking ...
rich c
Is it kiln dried construction lumber, or kiln dried furniture grade? Construction grade is dried to 19%, furniture grade to 6-8%. Makes a huge difference.
4/8/21       #3: Douglas Fir Cracking ...
Glen Harwell
Not good for furniture. It is a softwood and will always crack no matter how much it is dried. Lots of really basic questions lately from people who are supposed to be professional woodworkers.
4/9/21       #4: Douglas Fir Cracking ...
I have had similar problems with furniture grade Douglas fir. I am not sure whether the wood I used was kiln dried to a higher moisture content or whether DF is difficult to batch dry but some boards in the delivery of wood checked badly after breakout. I have been leary of working with it since in solid and I prefer to use DF veneer. I love the look of quartered fir.
5/10/21       #5: Douglas Fir Cracking ...
There is no inherent issue with Doug Fir as a furniture wood. Pine has been used for a long long time for furniture, casework, trim.
As long as it is kiln dried and kept at 6-8% it will be fine. If you use improper construction techniques you will get a higher failure rate than a hardwood because it is simply not as strong and the grain tends to be very straight, whereas hardwoods in general are not.
    • CP Adhesives
    • Anver Corporation
