Subject: Re: Euro hinges
Euro hinges
11/11/15
Hillary
I’m looking to replace 1980’s hinges with Euro hinges in a bathroom. I don't know what to buy. Blum is very confusing and I purchased the wrong one after speaking with them on the phone (pic attached of their part 38N358B.10). Another manufacturer would be fine too.
I measured the edge overlay to be 5/8”. The door has a lip edge that curves that measures 5/32 (pic attached). Please let me know what suggestions or questions you have to help figure this out. I’m sure someone here has done this before.
View higher quality, full size image (864 X 486)
View higher quality, full size image (576 X 1024)
11/11/15       #2: Euro hinges ...
EDDIE
look up cliptop blumotion 110*.
with a 0 build up plate. blum# 71b35550
Test this first on scrap!!!. The bore distance is so close to the door profile it may not work.
11/11/15       #3: Euro hinges ...
Bruce H
Hire a cabinetmaker. Euro hinges are not DIY. We sell time and ability... (this site is not for homeowner posts, as per the rules)
11/12/15       #4: Euro hinges ...
Hillary,
I would direct you to Rockler Woodworking Store (on line) or to one of their retail outlets if you have one in your city. They offer the Salice B series hinge which is designed for your application.
If you follow the link below you will find the information you need including installation details.
Best of luck
Rockler : Salice Hinges For Lip Doors
11/13/15       #5: Euro hinges ...
After some more thought, I can offer a much simpler solution. The Salice, Series U soft close hinge can have an edge bore distance up to 6mm (1/4"). This should work fine in your application with the finger pull.
Until the introduction of this hinge the edge bore distance for all compact style face frame hinges could not go beyond 3mm (1/8").
View higher quality, full size image (738 X 393)
11/17/15       #6: Euro hinges ...
Steve Member
Hillary - as Dennis suggests, check Rockler, not only for the sales staff, but for customers. I can't count how many times I have zipped in to grab something and found a homeowner customer at the counter with the same sort of problem and as a good guy I have commented, drilled, cut, or even turned a piece for them; such a person could give you advice and answer questions. The hinge you hold in the pic should be good for a ½" setback and might work. Be sure to take a door with you. Then if so, be absolutely sure to drill a scrap for test fit.
11/17/15       #7: Euro hinges ...
Steve Member
As I look around the room and at two kitchen jobs I did I have replaced the same original hinge, and installed the latter as new on similar profiles, You need some hands on review with someone on scrap to be sure it will fit.
P.S. I like the artwork in your cabinet :)
11/28/15       #8: Euro hinges ...
Hillary
Thanks everyone! We used the 3/8" - 5/8" Overlay Blum® 110° Soft-Close BLUMotion Clip Top Face Frame Hinges, Pair Item #: 33600.
Made a sample piece. That was very important. We tried several that didn't work. from Salice & Blum.
Thanks,
Hillary
