Biscuit Joiner
12/8/18
My 20 year old Porter Cable biscuit joiner has finally decided that its getting tired.
Back in the day I primarily used it for trimming the big houses. Occasionally over the years in the shop we use it for aligning counter tops or really long edge glued boards(no glue).
We've got a big trim job starting this week. I took the thing out of its box and went thru the various trial and errors of checking the blade(PC) swapping a brand new Elu(dewalt). Two different brands of biscuits. At the end of the day it probably needs new bearings.
I'm looking at the Makita 18v cordless. Since I've got a pile of batteries and every other Makita 18v other than the lawn mower and coffee maker, I figure is time to go cordless.
Anybody got one?
12/12/18       #2: Biscuit Joiner ...
Matt
Not the cordless, sorry, but I do have one of their fairly recent model 110v Makita biscuit joiners and thus far it's the best biscuit joiner I've purchased (compared against the old Freud, Porter Cable, and Dewalt).
It's definitely the easiest to set up, most intuitive, and lightest in the hand.
12/15/18       #3: Biscuit Joiner ...
Harold
Website: http://morantz Cabinets.com
Nothing beats a lamello. We also own the lamello machine for the tenso biscuits and it is truly amazing. Used every day in shop for but amd 45 degree joints in fine veneers amd deadlyvaccurate. Large choice of biscuits for many applications
12/18/18       #4: Biscuit Joiner ...
Harold,
If I was in your kind of business I would consider a Lamello. I rarely ever use a biscuit joiner. I need one specifically for a big trim job. Then it will sit around until we need it again. It wouldn't surprise me if a big box of Lamello biscuits costs as much as a Makita cordless joiner.
12/18/18       #5: Biscuit Joiner ...
Hen Bob Member
I 2nd the Lamello, money well spent.
Dont have to use fancy biscuits either.
1/9/19       #6: Biscuit Joiner ...
The Lamello machines are expensive and worth their price! At one point we needed a couple of biscuit joiners for on site work. didn't want to risk the Lamellos so bought Dewalts, not even in the same league!
1/14/19       #7: Biscuit Joiner ...
Justin
Th Makita corded joiner is a nice tool. The cordless is very under powered. Nice for the odd slot here or there but if you will be cutting any volume the corded will do better.
12/7/19       #8: Biscuit Joiner ...
dan Member
Have you looked at the Festool Domino? It has advantages and disadvantages. We have a couple but also use Lamellos. The Domino is much more flexible and you can easily make your own tenons. We send ours through the sander and like hickory and cherry best. One for strength and one for glue absorption. Pricey but well worth it if you use one often.
