Laminating using hydraulic press + Radio Frequency
3/18/18
jfhaegy Member
Hello everyone,
I'm a french furniture maker. I use a hydraulic veneer press with electrically heated plattens to laminate both sides of a 15mm poplar plywood pannel (0,5m by 3,1m).
I use PUR adhesive because 2 H-shaped aluminum profiles are inserted on the edges of that pannel and i need a perfect bond on wood and metal.
I would like to speed up the bonding using Radio Frequency. Does anyone has experience with HPL laminating + RF bonding? Does anyone has experience with turning a regular hydraulic press into a HF press?
Thanks a lot for your contributions. I can provide more details if needed,
JFH
