Wood Filler with laminate
10/1/18
JDJD Member
I have a plastic laminate repair job to do. We will remove the laminate and replace it but there are a few places that have seen significant impacts that caused some dents (largest is around 1" x 1" - most are significantly smaller than that) that will need to be filled in before re-laminating. Wondering what folks use to fill in those dents when using plastic laminate? Thanks for any help!
10/1/18       #2: Wood Filler with laminate ...
tyler Member
Usually bondo does the trick
10/17/18       #3: Wood Filler with laminate ...
LongEyeWood Member
Bondo is the only way to go. Don't waste your time with anything else
