ColorCore Cabinet door fabrication and edgebanding
10/12/21
John Member
Good Afternoon,
When working with ColorCore, Solicor or any other through-color Laminate how do you guys handle the edgebanding process for the door edges?
We typically edge the doors with strips of colorcore through the edgebander and then deck the front and back of the doors with colorcore laminate. This becomes a time consuming process.
A few times we have laid up colorcore on full sheets both sides, cut the doors out on the CNC and then ran the edges with PVC through the edgebander. Basically capping the colorcore which makes the through color no longer visible.
Is there an industry "standard" for this process? How are you guys doing yours?
Thanks-John
10/25/21       #3: ColorCore Cabinet door fabrication ...
Quicktrim
We cut on router then band with pvc.
We spec it this way and unless there is a request for other methods it's what we do .
Other methods get priced according to labor involved.
    • Limtech Industries, Inc.
    • Denray Machine
    • Cabinet Pro
    • Impact Search and Placement
    • RT Machine Co.
