Sawing and Drying
RE: Bandsaw blades breaking
7/3/20
Tommy Hart Member
We are having problems with our bandsaw blades breaking on a large horizontal bandsaw with 30" wheels, in which we are cutting hardwoods, primarily red & white oak.
We currently use Woodmizer Turbo blades which are 1 1/2 inches wide, 7/8" toothspacing, .055 thick.
Our question is if we set the blades by increasing the kerf on the blade, will our band blades break less?
What is causing our bandsaw blades to break?
Also, what is the ideal kerf to be used in cutting hardwoods?
Thank you.
7/4/20       #2: RE: Bandsaw blades breaking ...
Breaking at the weld or in the gullet? New blades or resharpened? Power feed I assume? Just recently an issue? Change supplier to get this batch? First thought is that you are entering the stock too fast. Try to start the cut slowly and then speed up. If a very recent problem, could be a bad batch of steel. Contact Woodmizer.
7/7/20       #3: RE: Bandsaw blades breaking ...
John Member
Have you checked the actual tension in the blades after you install them? I had no clue what the tension was in my blade; just followed the saw maker's guidelines. After a friend had several blades break on his mill I checked the tension on mine as reference. 24 ksi is what I measured, repeatably. I was shocked it was that high, but data don't lie. I've had just one blade break so far and it was one I had resharpened at least twice.
John
    • Forestry.com
