Let’s say you have a 12” wide
Icee with 1” of cup. If you cut this in half to get two 6” wide pieces, you will have 1/4” of cup. Rip again into 3” widths and each piece will have 1/16” cup. Of course, the side will not be a perfect 90 degrees to the face, so it will be necessary to re-machine the edges. Then glue the pieces back together. If glued in the same order as they were ripped, the grain will come close to matching. However, usually the 3” strips are random to give grain variation.
Air drying for ten years has a high risk of insect damage. Properly done kiln drying eliminates that risk. In either case, poor storage after drying can result in insect damage.
For a table that you want to have a flat surface after manufacturing, it is necessary to control the Final moisture content. Wood will not cup without having a MC change. As most homes and affixes have a wintertime humidity that results in about 6% MC, so, we target 6.8% MC target. In most parts of the US and Canada, air drying can achieve a low of 13% MC even after ten years. So, before use, the wood needs to be dried further...in a kiln, warm room, etc.
