Solid Wood Machining
Freud FTE2000 Router
9/5/17
Peter Verveniotis Member
Greetings , my Freud FTE2000 Router has been giving me problems with the variable speed control on a few occasions over the years whereby it stops working (burns out) . I'm tired of trying to locate a replacement speed module and I would like to know if any of you fellow woodworkers have similar problems to perhaps override the speed module and go direct power from switch to motor , it wont matter to me if it operates at full speed . Solid machine , lousy electrics .
Thanks Peter
9/9/17       #2: Freud FTE2000 Router ...
It limits the diameter/weight of the bit. You can't run a big bit at full speed in a 3 1/4"
9/9/17       #3: Freud FTE2000 Router ...
I consider that a poor choice for a commercial shop. No idea if you can hack the electronics. I will do minor repairs to hand tools, but replacing with new is much quicker and more efficient business practice in my book.
