Solid Wood Machining
mortising bits
10/31/19
James Doty Member
looking for a source for 16mm shank x 3/8" diameter x 3.75" length mortising bits
11/1/19       #2: mortising bits ...
Chuck Hicks Member
James,
Need more info,
1. Is this bit Carbide tipped or High Speed Steel?
2. Is the 3.75 the Overall length? If so, what is the cutting length?
3. Do you have a picture of this bit?
11/1/19       #3: mortising bits ...
James Doty Member
cutting length 2" to 2.5".
Bits I have are HSS but would prefer carbide tipped
Three cutting edges
11/1/19       #4: mortising bits ...
James Doty Member
these would be up cut bits
11/1/19       #5: mortising bits ...
Chuck Hicks Member
Let me know how many you are needing?
