Solid Wood Machining
Widebelt Sander Help Needed
11/21/19
Website: http://www.superiorcabinetryandmillwork.com
Hi,
I've got a 1984 model A.Costa single head widebelt sander. I am having issues with it sanding a slight dip on the trailing end of parts that are going through the sander. The dip is app. 4" to 5" from the trailing end. The sander has fixed rubber pinch rollers. One pinch roller before the sanding belt and one pinch roller after the sanding belt. The pinch rollers are on a cam, so I can loosen the set screw and move the rollers up or down and then retighten the set screw. Could the sanding dip be caused by the pinch rollers not being adjusted properly? And, if so, how do they need to be adjusted? The other issue that I am still battling is the tracking of the belt. This sander has air tracking on it. Basically, there is a limit switch on one side of the sander that has a spoon shaped part attached to it. There is a constant blast of air shooting toward the spoon shaped switch. When the sanding belt breaks the blast of air against the spoon shaped switch, it causes the belt to track toward the opposite way. There doesn't seem to be a problem with the belt tracking away from the spoon shaped switch, but a lot of times it doesn't want to track back toward the spoon shaped switch. I have recently redone and replaced a lot of the pneumatics associated with the tracking. I replaced the pneumatic solenoid valve (that controls the tracking), the air lines, air fittings, and two inline air regulators (control speed of tracking). I also had the dual acting air cylinder (controls the tracking) rebuilt with new seals. And, I put a new air regulator and oil mister on the sander. The oil mister is for the dual acting air cylinder that controls the tracking. I'm beginning to wonder if there is something wrong with one or more of the electrical components. I'm wondering if maybe a relay or a contactor is working intermittently. I'm not really that knowledgeable about motor controls. Does anybody have any advice about this? Or, would anybody know who I need to contact about helping me figure this out? Thanks in advance for your help.
11/26/19       #2: Widebelt Sander Help Needed ...
dave
To adjust the hold down rollers you can run in a pair of boards, one on each side, stop everything halfway through and adjust the back roller down onto the boards. You can also check the front roll adjustment. If you put enough pressure on the front roll you can make the trailing end pop up into the belt. If you are going back and forth from 24 grit to 100 you may need to readjust the back roll as the outbound thickness changes with belt thickness. You could check to see if the spoon is getting enough air fast enough to send the belt back in time. If the "out" cyl is pushing too hard or too far the belt won't head back in time. You might be able to adjust the stroke on the cyl to get less out travel and more "back". Good luck, "it's only a machine"
