Solid Wood Machining
Sawstop power loss
12/13/19
Tim  Member
Website: eastmanwoodworking.com
We have a 5 hp 3 phase Sawstop that is losing power. Much less power than usual. Belt is in good shape. Tension on belt is pretty good, but my reference point is a Unisaw with 3 belts that did not need to be super tight.
Any ideas?
12/13/19       #2: Sawstop power loss ...
D Brown
Is it slipping or bogging down ?
12/13/19       #3: Sawstop power loss ...
Peter Gagliardi
Test all 3 power leads, sounds like 1 phase has dropped out, which will cut power dramatically.
12/14/19       #4: Sawstop power loss ...
Make sure a pulley isn't slipping from a dropped out key or loose set screw.
2/8/20       #5: Sawstop power loss ...
keith farr
One of my Saw stops started to feel as it was losing power about a month ago At first It felt like changing to a High tooth count blade feels( harder to feed and bogs a little more) after about a week or so it started " groweling" ( a little bit of a Funny whine) I took table top of , pulled the belts and checked each bearing . All seemed good then upon turning the motor without belts connected I could feel alittle of resistence. I took to moter shop and upon an initial inspection they suspected a bearing failing Im waiting on them to fix and then I can let you know how comes out
