Solid Wood Machining
Balancing cutterhead on 24" jointer
2/23/20
Robert Pearce Member
I have a 24" Jonsereds jointer that had unfortunately been severly abused before I purchased it. I need to have new cutterhead gibs fabricated. I would also, if practical, like to have the cutterhead balanced with the new gibs. Advice please? Thanks in advance.
2/23/20       #2: Balancing cutterhead on 24" jo ...
If you don't have any luck finding a way to have the head dynamically balanced (I'd thing that to be insane expensive if at all) the other option is to static balance it yourself. Would involve a good bit of setup and a fixture bout may save the head and jointer if no better option.
2/28/20       #3: Balancing cutterhead on 24" jo ...
Charles
I had a 24" 4 knife Porter Jointer, more of a facing machine actually. It sounded out of balance so I took it to a shop that built racing engines had a dynamic balancing machine (used for crankshafts). That made a big difference. Don't remember the cost, but it must have been reasonable, as i was dirt poor broke back then.
