Solid Wood Machining
Need Help With A Newman Whitney Ripsaw
9/3/20
Hi,
I have a Newman Whitney KF-24 gang ripsaw. It started having a bad vibration and I'm trying to figure out what the problem is. Today we sawed two bundles of 2x8's with it without any problems. It was running great. I then took the blades off and set them to a different ripping width. I put the blades and arbor back on the saw and tightened everything down as usual. I noticed when I turned the saw back on that it was making a loud unusual noise and that there was a bad vibration. I have a laser mounted to the saw and I could see the laser beam shaking a little (It has never done that before). It had so much of a vibration that it obviously messed with the laser alignment. I took the blades back off and just put the shaft back onto the arbor to see if one of the blades might be causing the issue. It still had the same vibration without blades on it. The motor seems to spin freely. I can't detect any kind of wobble on the shaft of the motor. I unhooked the air from the disc brake to make sure that it wasn't possibly locking up. After unhooking the disc brake, the saw still had the vibration. I don't know if its possibly a bearing that is messing up or what. I had greased the saw somewhat recently, but I went ahead and greased it again and then turned it on. It still had the vibration. Does anyone have an idea of what could be causing the bad vibration? Any help would be appreciated. Thank you.
