Solid Wood Machining
Shelix head balance issue?
12/13/20
richard s newman Member
I have a Shelix shaper head, 3" diam by 4" long. It cuts great, but always left shallow valleys, .005" deep, 1" spacing. I put up with it for years, but finally decided to figure out what was going on. My spindle has less than 2 tenths (.0002") runout, so I knew it wasn't that. Took a test indicator to it, and found the head had .005 TIR, which explained the scallops. Luckily I have metal working capabilities, so I re-bored the 1-1/4" bore oversize and true, and sleeved it. Works great now, very satisfying.
My question is having moved the bore over .0025", is it necessary to rebalance the head? I don't feel any vibration, but my shaper is a huge massive machine. When I used the head on a Powermatic 26 at a woodworking school I taught at, it was a pretty unpleasant experience. Maybe the PM is too light a machine, and the speed was too high, probably 7000 rpm.
12/13/20       #3: Shelix head balance issue? ...
Dustin Orth
Years ago I bought some of the same hands. One ran just fine, the other had a nasty vibration just like your describing. I never did find out what was wrong with it other than I identified which one it was. Had it on a small molder and tried it on a shaper and had the same vibration on both. Powermatic super 27 shaper and an older Paulson 4 head push feed molder.
