Solid Wood Machining
Seeking Shaker passage door shaper cutter
2/16/21
Willis B
Website: http://www.bigelowdb.com
I need to build some 3 panel passage doors with a shaker profile. In this case I mean the profile has a simple 45 degree bevel. I've noticed there are a few ideas about whether "shaker" means square profile, or bevel, and at what degree. I always thought square was called "mission" style. In fact I'm building to match doors made by Jeld Wen and they call it Craftsman!
But in any case I can't find a cutter that fill work. Most cutters I can find are for cabinet doors, and I need something that will cut 1 3/8". I would prefer an insert head that could also be adjusted to cut 1 3/4 for exterior doors, but that is probably asking too much, and likely too expensive. I'm a novice with shaper tooling, so maybe there is something about cutter availability I'm missing...any help? - thanks
2/18/21       #2: Seeking Shaker passage door shaper ...
Thomas
Look at Woodweb's home page. You will find what you are looking for under
will get hits from all over the world. Using the resources on Woodweb you will find quality companies that can provide what you are looking for. Depending on your location you might be able to find a tool maker in your area. We use Meisenheimer Inc here in east TN. Local people who do great work. They also ship. There are many who advertise on Woodweb and most all are quality companies....mostly located in the grand old USA.
2/19/21       #3: Seeking Shaker passage door shaper ...
Jared Member
Look at Freeborn Tool's web site. They have stacked cutter sets & inserts to do what you need.
2/19/21       #4: Seeking Shaker passage door shaper ...
Great Lakes Custom Tooling makes this great head. It is on page 16 of the catalog I linked to.
You can have carbide inserts and steel backers made for it. So one head can be used to cut several profiles with insert cutters. It might be great in a case like this because when the job is done you have that profile forever but you can use the head for a stock profile or the next custom thing that comes along. We have a few of them and we really like them. Best bang for you buck in my opinion because of the flexibility.
Great lakes catalog
