Solid Wood Machining
Double surfacer issues
4/26/21
Mark Elliott Member
To those of you that are running double surfacers with the spring loaded carpet fingers, is there a way to "re-sharpen" them?
It is now 10 years old and the fingers don't seem to grip like they used to.
Any advice that someone might have would be greatly appreciated.
Mark
4/30/21       #2: Double surfacer issues ...
re
We did sharpen ours, from what I remember we took the slats apart one by one and chucked them in a drill against the grinder. At the same time we "flipped" the cross bars as they had bowed up. I have since replaced the fingers and also have a new chain we've yet to install. Of course ours maybe different from yours in construction.
4/30/21       #3: Double surfacer issues ...
Mark Elliott Member
Thank you re,
I'm going to open mine up and see what it's going to take to remove the slats.
Mark
