Solid Wood Machining
Bridgewood 708 moulder/planer
5/29/21
Jimb
My indeed roller axel bent,while in vise taking out axel from roller it dropped out of vise cracked in half.now in need arm and axel so I looked up Hussey for replacement.went with the multi pass kit because that would give me what I need.the 708 is the same thing as the hussey except it’s 3 hp.well the roller and arm are 5/8 shorter.I didn’t see where I could buy bridgewood replacement as it came from Wilkes machinery.anybody know where I could find out who might carry those parts.I will see if I can modify the hussey?
5/31/21       #2: Bridgewood 708 moulder/planer ...
Jimb
Ordered swing arm from grizzly looks like the fox moulder is longer
6/5/21       #3: Bridgewood 708 moulder/planer ...
Jimb
No Good on the grizzly to short and axel is different thread? Anybody.?
6/8/21       #4: Bridgewood 708 moulder/planer ...
TonyF
Jimb:
The thing about smaller machinery is that very often, different brand names and paint colors are applied to what is otherwise the same machine, just like store brands in the grocery store. One of the selling points of the Wilke/Bridgewood line was that they used American motors and electricals in their medium-duty Asian imported machinery.
I would see if there are parts available for various other machine brands that are similar, like General or Jet, but also "American" brands like Delta and Powermatic, and see if their part fits. Chasing down the actual manufacturer of these machines will be time consuming.
You might also consider finding out what a machine shop would charge to restore your part. It may be cost effective, given the time you will spend looking, the expense of the part when and if you find it, and the downtime cost of your machine.
As a last resort, you might consider a used W&H as a replacement machine.
Hope this helps.
TonyF
6/12/21       #5: Bridgewood 708 moulder/planer ...
Jimb
Yes i am having machine shop make me replacement part.I wish I could have found original,but it was me that dropped it out of vise.the infeed axel on the wh is the same,jim
