Solid Wood Machining
Quarter or Rift, 90 or 45.
9/29/21
michael foster Member
If I want to cut the most stable boards possible. Should I cut the boards so that the end of the board shows the grain at 90 degrees to the board face, or at 45 degrees to the board face.
9/29/21       #2: Quarter or Rift, 90 or 45. ...
Most stable is 90º.
10/2/21       #3: Quarter or Rift, 90 or 45. ...
BH Davis  Member
Rift cut is more like a 15° cut angle. This is nearly as stable as 1/4-sawn wood but eliminates the visible flecking in woods like white oak. Some projects call for rift sawn wood for that reason.
There is no point in cutting at 45°. You are theoretically losing 50% of your stability with no gain in appearance one way or the other.
So 1/4-sawn is the most stable with properly cut rift sawn not far behind.
