Solid Wood Machining
spindle nut
10/8/21
anthony t armeni
looking for spindle nut and washer for a sac sueri ts145 standard 1 1/4 spindle .
10/12/21       #2: spindle nut ...
A proper machine shop can make that in just an hour or two. If you have them make one, make two - the second one goes in your desk and is used only when needed.
10/14/21       #3: spindle nut ...
Kevin Jenness Member
Measure it and see if you can find a match at McMaster Carr. Otherwise, what David said
10/14/21       #4: spindle nut ...
The problem I have had with ordering large nuts is I don't have a way to describe said nut. Especially if it is missing.
I can count the threads per inch, but what about metric?
How does one go about defining threads on larger parts?
10/14/21       #5: spindle nut ...
Like David said get a machine shop to make it.
They will make it loose or tight. They also will machine it out of whatever material you spec or they have on hand. 4140 steel is pretty hard, most small shops will have a bit laying around.
