Solid Wood Machining
Wide belt sandpaper selection
2/16/22
Mark Member
Gona try here again with a more specific question.
I have done a lot of reading here and elsewhere on wide belt paper but honestly now I am bit overwhelmed with the selections. So looking for some direction.
The use will be for shop sawn veneer , and general sanding of solid wood. I typically RO to 180 then quick hand sand inline with 180. Mostly all furniture with the occasional frame.
Can anyone suggest a starting point?
Also would like to start with 1-2 belts of each before committing to the typ 5min order
Thanks! Mark
2/18/22       #2: Wide belt sandpaper selection ...
Dave Edgerton  Member
Mark for solid wood we use mirka hiolit XO cloth backed. We start 80 top level, 120 to smooth and 220 for final few passes with the platen down.
The 220 we are at using paper backed. 24" widebelt.
