Solid Wood Machining
RE: Large Handheld Orbital Sander & Machine Sanders
3/26/22
Kenneth Member
What is the largest handheld orbital disc sander that we could purchase to sand hardwood table tops?
Also, is there an inexpensive, round, open surface, machine sander that you run the wood table tops?
3/27/22       #3: RE: Large Handheld Orbital Sander & ...
Tipper Member
A 37” or larger wide belt sander would do almost 100% of the sanding for you. They are a lot more expensive than a drum sander, though. You could get a 7” orbital sander/polisher from Harbor Freight for around $90. That would be the largest handheld orbital sander that I know of
3/28/22       #4: RE: Large Handheld Orbital Sander & ...
Josh Koschak Member
GEM 11" H&L Orbital Sander w/Shroud
$659.95
3/28/22       #5: RE: Large Handheld Orbital Sander & ...
Shananae
Stroke sander
3/28/22       #6: RE: Large Handheld Orbital Sander & ...
Dave Edgerton  Member
I concur with Stoke sander. Had an 11' one near me going for 200$
3/31/22       #7: RE: Large Handheld Orbital Sander & ...
DOUGLAS P CONTI Member
there is a 12 and 18 inch one that is used for solid surfacing. It uses 6 inch discs and does a excellent job however they are pretty pricey
4/1/22       #8: RE: Large Handheld Orbital Sander & ...
Pete Anderson
Website: http://petesfloors.wordpress.com
If you would like machine that can get the surface flat in a hurry a floor edger that has a 7 inch disc can do a lot of work in a hurry.. The discs are available from 16 to 120 grit. The motor is one horse power. It's a little hard to not have a flat surface from sanding. There are two wheels that support the machine to help move it around since they weigh about 30 pounds. A big bag collects the dust, which can be used for a number of things. You may get one in a pawn shop for $350 on up, but a new edger can cost close to $2000. I use one to flatten a hump in sub-floors with 16 grit and also fine sanding with 120, which is the finest I use. A light touch is necessary with the fine papers.
