Solid Wood Machining
How is hand scraped flooring made commercially?
4/23/22
Mark B
Sorry, This is a question more out of simple interest more that anything. I, nor my shop, has any desire nor intention to make any flooring like this. For years it has seemed a nightmare to me to have a floor with highs that will wear immediately and lows that will likely never see wear. Seems a recipe for a floor that will be ground flat in short order on a very premature re-finish due to the wear on the highs.
With that, we get tons of requests for nosing and so on to be made, grooved, etc that will mate up with a commercial hand scraped floor. Anything we supply or re-work is smooth, no hand scrape but a sample is always provided and Ive always wondered what the machining process is for the factory hand scrape. Is it some sort of oscillating moulder head that oscillates in both x and y to randomize the depth and x location of the faux scrape?
Some samples we get it even have saw marks remaining (straight band sawn) under the finish as if they are moulding hit and miss?
Ive googled and youtubed try to see the moulder that pukes out this hand scraped but not landed on anything.
4/23/22       #2: How is hand scraped flooring made c ...
Dustin Orth  Member
The machines I've seen that do this kind of work are similar to a molder except instead of spinning cutters it's a shaft that has a straight blade and moves back and forth. Power fed like a regular molder so it's pretty quick at spitting material out.
4/26/22       #3: How is hand scraped flooring made c ...
Google is a wonderful thing!
https://www.youtube.com/watch?v=qcL5Kog7sQQ
4/27/22       #4: How is hand scraped flooring made c ...
Mark B
Dang, my google musta been on the fritz. I had searched foogle and the tube before posting but blanked.
Thanks Rich. I had envisioned similar operation but with cutter blocks.
