Solid Wood Machining
grizzly shaper trouble
5/11/22
mike klostermann
I have a grizzly 1026 3 hp shaper.
For some reason when i run my rails for cabinet door it comes out wavy. almost like snipe but all the way along the cut. I am using a power feeder and angle it towards an out board fence.
dose any one have a though as to what is happening
5/11/22       #3: grizzly shaper trouble ...
perley
You maybe feeding to fast. O not enough pressure on the feeder.
5/12/22       #4: grizzly shaper trouble ...
mike klostermann
Ok thank you,
ill give that a try
5/12/22       #5: grizzly shaper trouble ...
John
Is your outboard fence moved forward for the amount that the cutter is removing in relation to the inboard fence?
5/12/22       #6: grizzly shaper trouble ...
Is the fence flat? If it has a split fence, probably not and the wood is rocking back and forth on the fence.
5/13/22       #7: grizzly shaper trouble ...
Josh Koschak Member
Outboard fences are continuous and not split.
5/13/22       #8: grizzly shaper trouble ...
Matt Calnen
Also check that your spindle speed is on the faster setting. I remember once I switched from panel raising to running door sticking, I forgot to change the spindle speed back up. It makes a lot of difference.
5/13/22       #9: grizzly shaper trouble ...
There are two fences on the machine, they are definitely split in the center compared to one long straight strip. That casting that holds those two fences are notorious for not being well machined and straight. Put a good long straightedge on it and I'm sure you will see your problem.
5/14/22       #10: grizzly shaper trouble ...
Matt Calnen
To add to what Rich said, if the the fence halves are not in the correct plane, remove the fence assembly and run light passes across the face of the fence on your jointer. This will true them. The wood fence faces that my shaper came with were to thin to do this and not hit metal, so I made new thicker ones out of quartersawn hard maple. The quartersawn wears better and is stable.
5/14/22       #11: grizzly shaper trouble ...
Jon Member
Do you have a spring loaded fence that helps hold the stock against the outboard fence? If not I would recommend fabricating something that will hold the material against the fence.
Or if you do, maybe you do not have enough pressure holding it away from the cutter.
My guess is the material is being pulled into the cutter.
5/19/22       #12: grizzly shaper trouble ...
Erick556I Member
Is you ask me, there aren't enough pressure on the feeder.
5/22/22       #13: grizzly shaper trouble ...
Dustin J Orth
Double check that the power feed wheels are tight and running true, also don't forget to lubricate your outboard fence when you lube your table.
5/28/22       #14: grizzly shaper trouble ...
BH Davis  Member
If you are getting chatter marks on the full length of the cut you should look at the stability of the wood as it is passing the cutter head, and the cutter head itself.
Things to check are cutter sharpness, spindle bearings, power feed roller pressure and angle, hardening of the power feed wheels and properly waxed table surface.
I don't agree that a misaligned outfeed fence is likely to cause this. End snipe yes. Full length chatter no unless the fence is so far out that the wood doesn't touch it for about 50% or greater of it's length.
Personally I would think the most likely culprit is the spindle bearings. Been there, done that.
