Solid Wood Machining
Wide Belt sander platen material
3/27/22
Mark Member
I am getting crowning on parts no matter how light the pressure is on the platen, I am only using it on 180 final pass.
The platen felt and graphite was recently replaced and i think it may be to soft and thick, it is 1/2” thick. I did some searching here and it seems that “F1” felt is what i am looking for is that correct? If so what thickness? 1/4”?
Thanks for help in advanced
3/28/22       #3: Wide Belt sander platen material ...
Dave Edgerton  Member
Got a pic of the platen you can post? You can always switch out the felt for phenolic or hard rubber
4/3/22       #4: Wide Belt sander platen material ...
I'd never use rubber for the platen, there is a lot of friction with the cloth backed belts.
4/4/22       #5: Wide Belt sander platen material ...
I think graphite could be used with some firm rubber, and then the friction would be reduced. But, were it real successful, then sander manufacturers would ship it in their machines.
Hard felt, and the right sanding pressure should work fine.
4/4/22       #6: Wide Belt sander platen material ...
Mark Member
Thanks for the responses. I did a lot of investigation here is what i found.
The scm spec for the hard felt is 68 durometer, that is practically rock hard. They want $275 for that part.
They told me not to go any harder as the belt splice might transfer but a little lower is ok, i found that felt grade 26S1 is commonly used and its rating is 55-65. F1 grade i have read works as well but is a 35 duro for comparison.
Scm also specify 3M847 to adhere the felt to the platen. It’s expensive and I couldn’t find it in stock so i used 3m90. They did tell me to use at least an equivalent to the 3M847 or risk the felt moving around.
Also you need to calibrate the felt once on the aluminum platen. Here is the info i sent myself via email so I wouldn’t loose it . This is specific to the 25” sandya win but imagine it applies to others with the same type of platen.
I was told by some sources that PEC 303 was the best graphite to use and others the 500, I used 500 because it was available.
Platen
Correct Felt pn 0341643500C $270
Durometer 68, 12 mm thick
Can use other felt but not harder than duro 68, will transfer belt splice (I used 26S1 55-65)
Adhesive for Felt to Platen and graphite to Felt 3m 847 (I used 3M90)
Total thickness platen plus Felt 32mm (can be thinner but check that it will go below drum)
Glue Felt to platen with 3m 847 wait 24 hours
Using a 100 grit belt calibrate through sander to 32mm
Run at an angle no more than 12 degrees
Glue graphite on Felt with 3M 847 wait 24 hours (i used 3M90)
Graphite hang over felt ¼” each side (i did the same as the felt)
Max take off with Platen 0.002-0.003
Should be just a whisper
Should be able to see light between platen and wood (I think this is what he said)
So I think my platen issue is fixed but my 180 VSM belt is creating chatter marks from the belt splce that the platen won’t remove. I tried platen only but can’t remove 0.004 without crowning the wood which you need to do to remove the 120 scratch.
I also have a steel head so i think the scratch may be deeper then off a rubber head so maybe instead of 12 to 180 maybe i need to go 120,150,180.
I heard that the SIA toptec 1919 or 1920 was a good belt so may give that one a try.
1/17/23       #7: Wide Belt sander platen material ...
Adam West  Member
If you haven't got this all worked out just send me a message and I'll walk you through it.
You did fine on the platen but i use 3m super77 for holding the felt to the aluminum and the graphite to the felt instead of using the loose flap method.
