Veneer
Veneer LampShade
1/2/18
howard Member
Website: http://woodcon.net
Made a shade with two veneer layers but it did not give off enough light so I am going to use one layer veneer and a thin layer of plastic. What would you recommend for the adhesive? I was thinking of a slower setting cyano since it would dry clear? also, either acrylic or plexi ok? Thanks for your help!!
1/4/18       #2: Veneer LampShade ...
Josh Koschak Member
Put a brighter bulb in the socket :-)
6/9/20       #3: Veneer LampShade ...
Myron
Depending on veneer, create shape with single layer and carefully spray WB top coat.
