Veneer
how do you vacuum Vaneer with no bag
9/22/18
Richard Member
Website: http://cfandm.com
I have a table I am trying to a veneer the top to. It is permanently attached to the base so can not use a bag.
I saw at one time a way to take vinyl
and use some kind of rope like putty to seat the edge all around and then apply a vacuum to it. Any one give me an idea on how to do this and what that product might be.
The table has Formica on it with a Teak nosing around it I could some attach the vinyl sheet to. I will be putting teak over it and use a poly backed veneer and West System epoxy to attach it.
Emails are fine, thanks for any help. I have searched the web with no luck and am thinking about calling Veneer Supply also.
9/24/18       #4: how do you vacuum Vaneer with no ba ...
I would skip the vacuum all together for a table, use a sheet of melamine slightly bigger than your table, some hardwood or dimensional lumber even as caulks. A little bit of crown is good as you put those down and you use some clamps and you are off to the races. You can even use playing cards underneath if you want more pressure in certain areas for some reason.
This is very simple and does an excellent job.
9/24/18       #6: how do you vacuum Vaneer with no ba ...
Does epoxy stick to Formica?
9/27/18       #7: how do you vacuum Vaneer with no ba ...
Kevin Basto Member
The "rope tape" you are referring to is gum tape, bag tape, a mastic tape sealant actually made by West System (883 Vacuum bag sealant) for attaching vacuum bags to molds and other odd shapes, it is used extensively in the boat building composites and aerospace industry.
9/28/18       #8: how do you vacuum Vaneer with no ba ...
Jared Emery
Yes you can bag right to the edge of the table like you're thinking. Visqueen and Butyl tape are what you're looking for, and the big box stores sell what you need for a one time use bag. Epoxy will bond to laminate if you sand through the paper and get to the phenolic resin sheet underneath. The joint between the laminate and the teak edging will leak air, so you need to seal it up on the underside. I would brush on a bead of thickened epoxy, otherwise your vacuum pump will race trying to keep up with the leaks. I have a few more hints if you want.
1/13/20       #10: how do you vacuum Vaneer with no ba ...
shayla
Jared I would like more hints you have as i have a door i will need to make some sort of vacuum for. I am new at this so details are appreciated. thank you in advance
