Veneer
Solid wood substrait
12/2/20
TonyK. Member
I have some poor quality Cherry I want to use up. If I put Cherry veneer on both sides, will there be big issues? will veneer with the grain. Wood movement??
12/2/20       #2: Solid wood substrait ...
John Van Brussel Member
Website: http://www.veneersystems.com
You should be fine as long as the veneers are the same thickness on the face and back. You can even use a different species as long as it has similar properties to cherry.
12/16/20       #3: Solid wood substrait ...
BH Davis  Member
I've veneered cherry over cherry on just one side and it's held flat for years. My veneer though was 1/8" resawn figured cherry over a plain sawn core.
There is something to be said about veneering both sides as previously stated. Not because of the veneer but rather because of the glue line. If only on one side it could cause uneven moisture penetration into the core and subsequent cupping. I may have just been lucky with my project, or the stability may have come from the fact that my veneer layer was so thick.
Just make sure that the grain is going in the same direction on both layers plus you still have to follow best practices for gluing up solid lumber cores.
