Veneer
Veneering solid wood panels for exterior
7/21/21
Kevin Member
veneering crotch mahogany to a solid raised mahogany panel for exterior durability. the crotch veneer would only be on the flat of the panel
7/21/21       #2: Veneering solid wood panels for ext ...
Make sure you are making a balanced panel. I am assuming these are door panels. There are a few threads here on exterior door panels with a few strategies to ensure panel longevity.
Mahogany is stable and crotch on both sides with plastic resin glue or UF glue will be able to withstand heat and atmospheric moisture cycling. Assume expansion/ contraction rates for regular mahogany.
Direct sunlight and precipitation will deteriorate a finish quickly leading to wood degradation.
7/21/21       #3: Veneering solid wood panels for ext ...
rich c
I have yet to see a mahogany crotch veneer on a piece of vintage furniture without cracks in it. Any that is on interior furniture. Doing any kind of frame and panel on exterior work provides the perfect channel to catch water in the rail and style dadoes. Keeping up the finish will become a major undertaking for the customers. Refinish every 2 years probably.
7/21/21       #4: Veneering solid wood panels for ext ...
Crotch is full of short grain so this might be a good candidate for cross-banded veneer. Many of the checks and cracks in antiques is due to the application method and hide glue. Careful veneer selection, modern adhesive and cross banding will greatly improve the product. But I wouldn't guarantee the job if there wasn't sufficient protection from water and sunlight
7/26/21       #5: Veneering solid wood panels for ext ...
We make 7 ply panels for exterior doors frequently. The 7 plies comer from a core, solid wood for the raise, then a cross band than a face. These are balanced panels - same thing both sides.
We have used crotch Mahogany, and they did have some small splits over time. Be sure your customer understands this.
