Wood NetWork
Subject: Re: need help creating mdf door with glass
12/12/14
Dave Adam  Member
Website: creativeconnectors.com
I have been asked to make an interior sliding barn style door from mdf with glass in upper section. please see attached picture. I have made one before using all 3/4" mdf. total thickness 2.25". problem is that the glass was not supported well because of the clearance between front and back panels. I made the lower panel one piece the width of the door. and glued the rails on the front and back face. the outer stiles went to the top of the door and i used smaller pieces around the window sandwiched between the stiles and upper rail. this allowed the window to fit into the slot but the slot was 3/4".
thought about doing more traditional job by slotting the outer stiles to slide 1/4" center panel into and glass at top. but without gluing 3 pieces of mdf to make the stiles and instead having 1 thick piece, worried about the mdf bowing.
does anyone have a simple idea of the best way to make this style of door?
Thanks in advance for your help.
12/13/14       #2: need help creating mdf door with gl ...
History will offer you all the answers you need. Look at existing sash work and note how the glass is set into rabbets, with wood stops to hold it in place. There are many reasons why this is the best way to do this, and there is no need to re-invent the wheel.
MDF, while the most gawd-awful material on the planet, will still allow the use of some wood to hold the glass in place.
    Excel Wood Products
