Wood NetWork
Workbench question
11/20/20
Hunter Member
I need to build a new workbench for the shop and I’m think the Holtzapffel style. I don’t currently have enough of a single species to make the whole bench. My question is could I use one for the base and another for the top? (does this present any issues that I may not realize?)
The two species I would be using would be white oak and heart pine. The pine for the base and white oak for the top I think.
11/21/20       #2: Workbench question ...
My concern with the pine is that being a soft wood, it would compress and loosen the tenons in the joints both in the top and the leg rails. There is quite a bit of racking force imparted on the joints when planing for instance. Another harder wood might be a better bet.
I'm no expert at bench building so it may not prove to be a problem.
11/22/20       #3: Workbench question ...
Dustin Orth
If you are using true old growth heart pine, you will be fine. Lumber yard pine, not a chance of it staying flat and as stable as you want. To much moisture content in that stuff. Also try using quarter sawn oak as much as possible, not to mention beautiful, very stable.
    Excel Wood Products
    • Limtech Industries, Inc.
    • Denray Machine
    • Cabinet Pro
    • Impact Search and Placement
    • RT Machine Co.
