Wood NetWork
Edge Bander Suggestions
9/16/21
Matt Member
Looking for recommendations on an edge bander. We don’t do a lot. May do a couple hundred feet a month. However, when we do it right now we rip laminate, glue it on with contact adhesive, trim it off and file it in. But every time we do 3 or 4 of us look at each other and say how nice it would be if we had an edgebander.
I’d like one that could do both plastic laminate and PVC (I’d be fine if it only did .018pvc but if it could do 1mm, 2mm, 3mm that would be awesome). We have as much need for contour as we do for just straight. So even if it was something that just applied and we still had to trim by hand it may be more efficient than what we are currently doing.
I don’t want one that has a glue pot that requires 2 hrs of cleanup before or after every time I use it. I’ve very quickly looked the unit by festool and though of taking a closer look. Ideally looking for recommendations on one that is $3,000 - $5,000.
10/25/21       #2: Edge Bander Suggestions ...
Nate Cougill  Member
Website: http://www.cougilldiversified.com
Have you seen the product offerings from Maksiwa? I played with their glue pot system and flush trimming station at AWFS this year and was really impressed. You could be into their system for under $5k with accessories and freight.
10/27/21       #3: Edge Bander Suggestions ...
Ken Member
I spent some time checking out the Maksiwa at AWFS too. I believe it's made in Brazil. For me just a couple of edge banding jobs a year. I would also consider it when the time comes.
    Excel Wood Products
