Wood NetWork
design help
11/4/22
Jimmy
Customer wants a built in bookshelf. It is in a upstairs room with angles ceilings. I am looking for advice on what software to use or someone to hire to design the unit with material and cut list.
11/6/22       #2: design help ...
Peter Member
Website: http://www.petermoffadesign.com
Because you have not shared your particular area of expertise, I'm not exactly sure where your line of work fits into this job you are describing. There are many, many software programs like SketchUp, AutoCAD, TurboCAD, etc. that could be used to generate drawings and cut lists, but they take some time to learn. If you have the time and are willing, then you can train yourself - this is what I have done.
Accurate and reliable dimensions, angles etc. must be taken at the site, so as to avoid problems like things not fitting correctly. Someone is ultimately liable for this information and it's best to have that clarified beforehand if you are working with other people.
Perhaps you might need to find someone with CAD (computer aided drawing) skills who you can give accurate dimensions to, who could generate drawings, cut lists etc. And you still need to work with the customer and the CAD person to develop the design that the customer will be happy with.
I'm not sure how simple or complex your design is...if it's quite simple, sometimes it's easier to just hand draw everything and figure it out on paper.
Peter
11/6/22       #3: design help ...
Bruce H
lay out the project onsite. no software is going to do what you are asking unless you have exact information. you'll get that by making a pattern and laying out the cabinets. at that point you don't need software.
    Excel Wood Products
