Subject: Re: Minimax me20 short circuit
4/19/24
Connor
Hey guys,
I've bought a beater of a 2012 minimax me20
I've got a fair amount of cnc trouble shooting experience and I've put days into getting it up and running. I was 90% of the way there. I'll I needed to do was get the edge trimmer to run consistently.
It would find the correct position on start up but not reset to the correct rest position. I made sure the pneumatics were all correct then looked at the relay that activates it. It was obviously a new part someone had put on. At 3am... instead of double checking that it was running at the correct voltage, I decided that they must have wired it backwards... I swapped the default position to closed instead of open, and now can't get the machine to turn on. It has power and the little transformer inside of it is reducing the voltage correctly but I can't find what I short circuited....
Anyone know what trouble shooting steps to take from here?
4/20/24       #3: Minimax me20 short circuit ...
Roy Cameron
Check all the fuses
4/20/24       #4: Minimax me20 short circuit ...
Deciding someone else made a mistake with electrical components works as well as it did for you. Tracing wiring and components with a multimeter is the only way to troubleshoot. Deciding is like guessing, it quite often makes smoke!
    • GreCon
    • ECabinet Systems
    • American Fabric Filter Co.
