Lease terms
1/7/24
Neo Member
I should be signing a lease soon on a small warehouse space for my 1-man RTA and custom cabinet business. I've had several commercial leases in years past that I probably haven't negotiated as well as I could have, and I want to be sure I do it right this time.
Price is not the question, I've found a well-managed space at a rate that is priced well below anything else I can find, with no NNN or CAM fees. But how long of a lease should I sign?
On the one hand, I want to lock in this rate for as long as possible, as commercial real estate only goes up in my area. Also, the ownership will soon be handed to a new generation of the family, so I want to be sure I can stay in place and not be forced into an expensive move.
But on the other hand, what if I grow out of the space? Or what if the business tanks and I'm stuck with a lease that I can't afford?
The landlord will likely write an annual rent increase into the lease. What percentage is fair?
1/8/24       #2: Lease terms ...
Sam
Typically a lease term is 5 years. I am sure there are some that will go 10 if you look hard enough.
2.25% to 3% i believe is a standard yearly increase from what i have seen.
If you out grow the space or go under, there is always an option to sublease the space but this will probably need to be written into the lease from the get go.
1/11/24       #3: Lease terms ...
Paul Downs
3 year lease with option to renew for 2 more. That's how I've done it with my landlord.
2/21/24       #4: Lease terms ...
brianelmore Member
Typically three years or less. Short-term leases allow you to adapt as your business changes. If you’re a startup, this flexibility ensures you won’t be stuck if things don’t work out.
3/18/24       #5: Lease terms ...
Gonzalo Torres Member
Usually no more than three years. You can easily adjust to changes in your business with short-term leases. This adaptability will save your startup from certain doom in the event that things don't pan out.
    • Machine Bid
    • Air Handling Systems
    • Texas Woodworking Festival
    • INNERGY
    • Better Vacuum Cups, Inc.
    • TradeJobPlacement.com
