Subject: Re: fillers on frameless cabinets
2/28/19
Brett
Hi,
Recently we have been told by our installers that they prefer hardwood fillers attached to framelesss cabinets instead of plywood or mdf. The problem with hardwood is when attached to mdf is it seems to be leaving a visible joint(see pic). Would this be due to the filler being hardwood and therefore maybe allowing some swelling to occur? What do you guys use for fillers on painted cabinets or stained cabinets?
2/28/19       #2: fillers on frameless cabinets ...
The glue needs to dry for a few days before you can spray it. The MDF is absorbing water from the glue and swelling. After you sand flat the water evaporates out, and it leaves an indent which you see.
3/1/19       #3: fillers on frameless cabinets ...
Ryan
So you are building MDF frameless cabinets?
3/1/19       #4: fillers on frameless cabinets ...
Brett
Yes, when they are paint grade we use raw mdf. I believe many shops use raw mdf for paint grade but let me know if there is a better way.
3/1/19       #5: fillers on frameless cabinets ...
Tyler
https://www.columbiaforestproducts.com/product/classic-core/
Thank me later. An infinitely better product to use for these applications as opposed to just a raw MDF cabinet.
3/1/19       #6: fillers on frameless cabinets ...
Tyler
I meant to add that I order this classic core product with no veneer or laminate on it. I just use the MDF face on the plywood substrate as a paintable surface.
3/1/19       #7: fillers on frameless cabinets ...
Adam B Member
Leo is 100% correct. You have 2 different materials that absorb the glue/water content at different rates. If you connect these different materials together and sand them flush before the glue has cured 100% the absorbed water will evaporate out of each piece at different rates/amounts leaving this seam visual.
3/1/19       #8: fillers on frameless cabinets ...
Jonathan Mahnken
Tyler the classic core IS better for strength and weight, but at more than double the material cost, and it still wont be as flat of a finished surface in the end.
3/4/19       #9: fillers on frameless cabinets ...
Bruce H
If the cabinet has a door I step the wall scribe 1/8" in front of the box. If there is no door then I step it back 1/8". Doesn't cause an issue with the paint line.
3/5/19       #10: fillers on frameless cabinets ...
Brett
Bruce, what do you do about crown molding on upper cabinets when stepping the filler back or forward?
3/5/19       #11: fillers on frameless cabinets ...
Tyler
While the material cost may be higher than raw MDF, it is cheaper than a 2s prefin maple ply, or atleast the material we buy.
I don't necessarily agree with your opinion that it doesnt have as flat of a finished surface in the end. We have had nothing but good results when using this product in this application. Maybe you have had a different experience, but we have had great luck.
3/5/19       #12: fillers on frameless cabinets ...
Bruce H
I run the side panels tall then apply a trim board on the front to and attach the crown to that. I leave a vertical space between the top of the box and the bottom of the crown, in that way the wall scribe doesn't interfere with the crown.
3/5/19       #13: fillers on frameless cabinets ...
Another option if you do a 2mm or so gap between doors is to have the filler strip even with the doors and it gives you another gap and the joint is hidden behind the door.
3/5/19       #14: fillers on frameless cabinets ...
Similar to this.
View higher quality, full size image (1800 X 1200)
3/7/19       #15: fillers on frameless cabinets ...
Pdub
I disagree that classic core is better than MDF for finished interiors. ALL ply core has stability issues. It likes to potato chip and not stay flat. Especially fun if you're nesting CNC. It's also not a consistent thickness. So if you dado, you will see a wavy joint line. Then there's the cost.
MDF is superior in every way except weight and water resisitance. If you use a good finish, the latter shouldn't really matter.
3/7/19       #16: fillers on frameless cabinets ...
Pdub
To the original question. Like everyone is saying, you have 2 different materials absorbing at different rates. Even if you wait and follow the former advice, the wood part will move seasonally and that line will show. It's the nature of white paint and shadow lines.
We step our fillers forward to be flush with the door. If it's an open cabinet, we just go faceframe.
