Subject: Re: Light showing around doors
10/30/20
keith farr
I have customers complaining about light showing around doors when we do glass with lights inside the unit I use Blum 120deg clip top hinges and the little bit of space the door stands off the frame allows light to escape around the door edge > Customers show me pics from internet that show cabinets with no light showing My only solution I can think of is weather stripping. Is there anything im not thinking of? Thanks
10/30/20       #2: Light showing around doors ...
Overlay doors.
10/31/20       #3: Light showing around doors ...
It sounds as if the OP is talking about overlay doors.
Once upon a time, better woodwork used inset doors that sat in rabbets on all four sides, pairs had meeting reverse rabbets to maintain the light tight. Butt hinges and catches of some kind also were employed. Doors were rabbeted to keep out bugs and dust, and to prevent seeing into the cabinets.
This is easily done with conventional face frames going to 1-1/4" thick and 3/8" wider. Join with M&T and lap over the rabbets. Make another rabbet for the cabinet ply panels or intersecting frame and panels.
Some of the European cabinetmakers even had small silicone bulbs to silence the closing door and seal it further from dust.
Overlay doors will still have a gaps that let out light around the perimeter.
10/31/20       #4: Light showing around doors ...
Patrick Gilbert
Some of the European compqnie markets use a T molding that was similiar to weather striping.
You might check on Outwater or maybe Haefle
11/1/20       #5: Light showing around doors ...
Matt Calnen
I make the plywood of my boxes set into the opening of the face frame 3/8”. Use a full crank Hinge and 9mm plate to get the door overlay correct. Using this hinge and plate gives you just enough room to get the LED Strip lighting along the edge of the cabinet and not interfere with the hinge. The edge of the plywood box also acts as a stop for the doors. I usually make the face frame a 1/16” thicker than the door with this set up.
11/1/20       #6: Light showing around doors ...
jonathan mahnken
3/8 inset with rabbet between pairs... or full inset with the case material set into the opening 1/4" Dont get too hung up on what they saw in a post or magazine. This is not real life. people have all kinds of outrageous particulars/demands based on what they see on instagram and pintrest. I could not see weatherstripping as a long term solution to this
    • Western Dovetail
      Custom Made Dovetail Drawers
    • Template Services
    • Air Handling Systems
    • TradeJobPlacement.com
    • WalzCraft
    • Lignomat
    • GreCon
