Subject: Re: Moisture content in doors causing issues?
4/8/21
RMS
We got busy and tried outsourcing doors to a supplier we used years ago who we knew to do good quality. We ordered in several paint grade shaker doors (13/16”x 3” brown maple frames with 1/4” mdf panel- square inside profile). We are having gaps/opening more than we are used to by a far margin. Causing us to putty a lot and me to worry a lot about future paint breaks at the joint. Doors are flat and not warped. Test at 6.0 both when the pallet arrives, in finish room and after hanging finish doors on cabinets. Door maker says our shop is allowing moisture problems that cause the gaps. But shop stays 55-60 degrees and we are testing the moisture content. Here’s a piece info for you wood detectives- on almost every single door out of hundreds the stile is sticking past the rail a 1/64-1/32”. In other words is you were to put on edge sander and sand flush you’d only sand end grain of stile. To me this means the doors are LOSING moisture not gaining moisture (their claim). We are 6.0 and have tested other wood to make sure our meter is working correctly. What do you think?
4/8/21       #2: Moisture content in doors causing i ...
Leo G
Sounds like your shop might be too dry if the wood is shrinking enough to have the rails shrink under the styles. 6-9% is a good range, 6% is definitely on the drier side meaning humidity is on the low side.
4/9/21       #3: Moisture content in doors causing i ...
RMS
It might be for your part of the country but for our area it is the norm. It’s semi arid desert. 13” of annual precipitation. Similar to door shops location. I tested a 2x4 that was sitting in 2’ of snow until a month ago and it was 8.0. Shop is minimally insulated and heated with non vented propane (releases a fair amount of moisture) and kept at 55-60 degrees. If I’m drying out these doors too much with these conditions can you imagine an HVAC controlled shop.
4/9/21       #4: Moisture content in doors causing i ...
I think your assumption is correct - the door manufacturer is working wood that has not acclimated. They may be working within the standard of 8-10% MC but that is not sufficiently dry for your location. It's not a fair argument on their side to say your shop doesn't have enough humidity because in all likelihood the final destination in your local will be as dry or drier.
On the good side, while putty in the joints is not ideal, the movement in the wood will be much less than what you are seeing on an annual basis. The MDF panel won't be an issue either.
You can do a little math to find the MC of the stock before manufacturing using the shrink calculations by plugging in the frame discrepancy into formula to solve for MC difference. My guess 1/32" over 3" is a big moisture loss (sorry I'm too lazy to do the math while I am having my first coffee)
4/9/21       #5: Moisture content in doors causing i ...
Do not confuse temperature with humidity.
It is obvious that the rails are shrinking in width. If you mic'd the stiles, you would see they gave up a bit of dimension.
No one cares more about your work than you. No one.
Your door supplier cares first about his business, you are on down the list.
    • American Fabric Filter Co.
    • Impact Search and Placement
    • Palmetto Cabinet Doors
    • Texas Woodworking Festival
    • Country Saw & Knife
    • Limtech Industries, Inc.
