Subject: Re: Making L-shaped flat mouldings efficiently
9/5/22
Matt
Looking for ideas on simplifying the process of making L-shaped flat mouldings (a "flat crown") that are applied to cabinets as a top-mount option.
The face portion is about 3" tall, the cleat is likewise about 3" wide, all made from whatever 3/4" material matches the doors. Just for context, these are contemporary flat-slab kitchens that do not go all the way to the cieling, so we attach these top of the cabinet by screwing them from the top down (no visible nail/pin holes).
We're going to need to be assembling 100-300lf per day of this material, and we need a process that will work for prefinished materials such as melamine and high gloss acrylic overlays as well as with painted plywoods/MDF.
We prefer to make these in 8-12ft sticks depending on what the chosen material will allow.
We've considered grooves and lamello biscuits, and just assemble with squeeze clamps. Pocket screws will work but nobody wants to hit a pocket screw on the miter saw out in the field. I don't think anyone makes a fiberglass screw that's strong enough for this.
Should we look into investing in machinery that makes slide-connectors work here?
9/5/22       #2: Making L-shaped flat mouldings effi ...
There are two basic wats to work wood - additive and subtractive. You can add, join, fasten wood together to get what you need, or subtract by carving the parts out of larger pcs. of wood.
I think milling a t & g joint along your parts will allow for easy yet square assembly with glue and pinners/staplers.
9/5/22       #3: Making L-shaped flat mouldings effi ...
Matt
T&G is a nice idea that I hadn't thought of, it would certainly allow for great accuracy. We don't currently have shapers set up, and I'd want to do this with a power feeder for consistency's sake. But, I will add this to the list.
9/6/22       #4: Making L-shaped flat mouldings effi ...
Hen Bob Member
we do these all the time. Just regular miters and clamp with packing tape . But in the long run miter lock cutter on a dedicated shaper would be the most efficient
9/6/22       #5: Making L-shaped flat mouldings effi ...
Jared
A side note to keep your L crown out of the clamps, whether you choose to lock-miter or not, you can still use pocket screws to hold while the glue sets and back them out after. The installers won't hate you anymore.
9/15/22       #6: Making L-shaped flat mouldings effi ...
Quicktrim
1/4 MDF spline,
Can easily be done on the table saw until you have a shaper and power feed setup .
10/20/22       #7: Making L-shaped flat mouldings effi ...
Bruce H
I use a reversible glue joint on a dedicated shaper with a power feeder. glue and clamp to make "L" shaped molding.
    • American Fabric Filter Co.
    • Impact Search and Placement
    • Palmetto Cabinet Doors
    • Texas Woodworking Festival
    • Country Saw & Knife
    • Limtech Industries, Inc.
