Subject: Re: Cabinet Door Shaper upgrade
1/6/23
Dana Trumpp Member
Getting tired of resetting fences to make doors. I made fences that lock into place with roll pins then a few bolts to hold it. Seams to work great. I am wanting to add DRO to my grizzly 1026 shaper. Hoping to record heights for cutters, so resetting is quick and accurate. Any thoughts on brands?
1/6/23       #2: Cabinet Door Shaper upgrade ...
Dana Trumpp Member
Added 1 more photo
1/6/23       #3: Cabinet Door Shaper upgrade ...
Jr Lee
Website: http://leecabinets.com
Proscale from accurate Technologies. A few more $$ but better than Wixey or?? I started out with Wixey and another cheaper one but regretted it.
Jr
1/7/23       #4: Cabinet Door Shaper upgrade ...
Wixey makes poor products. Don't waste your time trying to make them work & your money.
1/7/23       #5: Cabinet Door Shaper upgrade ...
Dana Trumpp Member
Per Jr post. I called accurate tech. Sounds like you can make it work. I can make brackets and tap holes. 400 for the basic 10" model. He said they see 15 yrs before need needing replaced unless a accident happens. This sounds better than a $30 one.
1/8/23       #6: Cabinet Door Shaper upgrade ...
Yavuz Member
Cheap but works for me. Just make a robust DRO install inside the cabinet.
View higher quality, full size image (5325 X 3004)
1/9/23       #7: Cabinet Door Shaper upgrade ...
The Accurate Tech Pro-Scales use remote readers. Locate them where you need to, and set the readout display where you need it.
1/9/23       #8: Cabinet Door Shaper upgrade ...
Bruce H
I can't see the expense or effort in adding a DRO to your existing machine. IMOP it would be much more cost effective to get another shaper instead of changing set ups. I cope and stick on one machine without changing set up. I do have to move the feeder out of the way to allow for a cope sled. Kind of a pain in the ass. I don't change the fence or spindle height, bits are stacked. I do use an outboard fence for the stick profile.
If you want to change spindle height you can get a magnetic digital height guage from Amazon for about $62.00. Too simple and works really well. If your spindle is taller than the guage, put it on a pair of 1-2-3 blocks.
Fence settings are easily accomplished by putting a 3/4" X 3/4" plug (maybe 12" long) in the miter track slot. Cut a plywood spacer between that plug and the fence dimension you want. I have several spacers so that I can get back the original set up without much effort.
The next thing you can do is machine a bushing to set your bit stack so you don't need to change the spindle height, I have several profiles in use and change them with out making adjustments.
Digital Electronic Height Gauge with Magnetic Base
    • American Fabric Filter Co.
    • Impact Search and Placement
    • Palmetto Cabinet Doors
    • Texas Woodworking Festival
    • Country Saw & Knife
    • Limtech Industries, Inc.
