source for large range hood corbels?
6/13/16
Folz Cabinet
Where can you buy large range hood corbels? 14-16" tall around 22" deep and 5-6" wide
6/13/16       #2: source for large range hood corbels ...
Mike Fuson
I highly doubt you'll find corbels in those dimensions. 22" deep and 16 tall would kinda be an odd looking corbel in my opinion, everyone is different though.
I buy quite a few large corbels, my go to place is Osborne. I've also bought from Vandyke, Archetectural depot, Designer Millworks, Corbels.com
6/13/16       #3: source for large range hood corbels ...
Leland Thomasset  Member
We have made large custom corbels for customers on our cnc. If you have a sketch or even a drawing I can send you a proposal
http://cnc-cabinetparts.com
6/14/16       #4: source for large range hood corbels ...
james mcgrew Member
Depending on feature or style desired combinations can be used to achieve a set measurement. do you have a plan or a photo. I to like Leland have done them by cnc as well
6/14/16       #6: source for large range hood corbels ...
Folz Cabinet
I would need 2 close to drawing 5" thick and 3 scaled down for on the bar around 12" tall 8" deep and 3.5" thick
6/14/16       #7: source for large range hood corbels ...
james mcgrew Member
Website: http://mcgrewwoodwork.com
Easy enough, if painted use 1" mdf if stained use specific hardwood
We use two outside profiles and 4 inside profiles set back 1/4-1/2" then a cleat is installed at the back of the corbel, if you make a template you can use it over and over. if you have a cnc i can send the dxf
View higher quality, full size image (757 X 799)
9/2/20       #8: source for large range hood corbels ...
Albert Member
Website: https://albuquerquehoodcleaning.com
Yes, I think its hard to find that huge a size. If you want to buy ready made, I would suggest Osborne as well.
    • RT Machine Co.
    • GreCon
    • American Fabric Filter Co.
