Panel Genie
Hinge for Mitered door / end panel
10/11/18
Brent Member
Thanks in advance.
Frameless cabinets - Rift cut White Oak
Horizontal grain - upper cabinet end panel
I'm 'wrapping' the grain around from the end panel to the door -- so I cut the end panel with a mitered edge -- and the door with a mitered edge (hinge side).
Now I'm surprised that I can't find a free-swing hinge (full overlay) for this application....
Any ideas?
10/11/18       #2: Hinge for Mitered door / end panel ...
Blum 71T7600N
Pull the spring if you have to have it free swing.
PDF]CLIP top 155o for mitred application
10/11/18       #3: Hinge for Mitered door / end panel ...
cabinetmaker
Soss. You’ll have to glue on an edge of the miter for a good square cut. Then rip it off
10/12/18       #4: Hinge for Mitered door / end panel ...
Hello Brent,
The Salice “B” Series hinge for profile edge doors is ideally suited for doors which are mitered into the edge of the cabinet. This has been a fairly popular design element in contemporary office furniture for several years.
For this application, the “B” Series hinge with the Push to open feature would be used. There is no “B” series in free swinging. The Push hinge requires a slight pressure to be applied to release a magnet then the door opens automatically. No handles are required.
You would need 3 components
CBPQA99 B Series hinge with Push feature
BAR3R29 2mm hinge mounting plate
DPASNB Magnetic release device
DP39XXG Magnetic device strike plate
Attached is a sample drawing of a mitered cabinet door using the “B” series hinge and a page from the Salice catalog featuring this item.
Best of Luck,
Dennis
View higher quality, full size image (584 X 832)
View higher quality, full size image (1944 X 1516)
10/18/18       #5: Hinge for Mitered door / end panel ...
cabinetmaker
Thanks Dennis
    Lamello
