1" overlay euro hinge
2/25/19
Kevin Jenness Member
Is there a two piece clip type euro hinge available that will give a 1" overlay on a frameless box?
I would prefer not to use the tec face frame hinges. I seem to recall that a 170 degree hinge with a restriction clip might do the job. Suggestions?
2/27/19       #3: 1" overlay euro hinge ...
Hey Kevin,
You’re pretty accurate about a solution here. I can think of 3 possibilities from Salice.
1. If you can live with a 15/16” overlay, you can use a 155 degree or a 94-degree Salice hinge with a 0mm mounting plate. You would not need the restrictor clip and would get the full opening with the 155-degree hinge. A 9mm edge bore distance would be used.
2. If you must have the full 1” overlay, then your solution is correct. You would use the 155-degree hinge, 0mm mounting plate and the restrictor clip to limit the opening to 120 degrees. A 9mm edge bore distance would be used.
3. Another solution would be to use to use the Salice 94-degree, F series hinge with a 40mm cup. With this, you would use a 0mm mounting plate and a 6.4mm edge bore. With this hinge, you could get up to a 1-3/8” overlay.
Here are 2 drawings showing solutions 2 and 3.
Best of luck,
Dennis
View higher quality, full size image (548 X 814)
View higher quality, full size image (548 X 818)
2/27/19       #4: 1" overlay euro hinge ...
Correction on point #2:
2. If you must have the full 1” overlay, then your solution is correct. You would use the 155-degree hinge, 0mm mounting plate and the restrictor clip to limit the opening to 131 degrees. An 11mm edge bore distance would be used.
Dennis
2/27/19       #5: 1" overlay euro hinge ...
Thank you, Dennis.
